Originally shared by Eugenia Martín Labyrinth medallion. Labyrinth-shaped gold medallion.
Labyrinth-shaped gold medallion. The labyrinth is formed by a single loop.
Manifold mesh with 9,156 quads (100%). No faces intersected or distorted. No poles of more than 5 edges. Suitable for printing. Render Blender Internal.
  • Medallón dorado con forma de laberinto.
Modelo formado por un sólo bucle con 9.156 quads (100%). Sin caras interseccionadas ni distorsionads. Sin polos de más de 5 aristas. Apto para imprimir. Render Blender Internal.
Coool! Do you have the source files? I’d love to print it :slight_smile:
@Luis_Diaz Thank you.
All models of my posts are original, with good topology and original textures. Also some rig. I always try to meet the requirements of addon for 3D Print, although none have ever printed. They are made with Blender.
I sell my models in TurboSquid where I have some free. This model is a test for a brain coral I’m doing and did not intend to sell it, so I can make you get the file for free as you are interested.
I think before printing should be subdivided, because it is a low poly model. It would also have to close the latch so that the chain does not pop out and you can lose.
@Eugenia_Martin will be great to print the model if you send it to me :slight_smile:
@Luis_Diaz Tell me how you sent and in what format.
@Eugenia_Martin it will be great to have the source file and a stl file to my email luis@drmaker.es
@Luis_Diaz I sent in .blend format.
I closed and extended to the ring hitch, to make it more secure and robust.
@Eugenia_Martin thank you :slight_smile: will print it soon and show you the result
@Luis_Diaz Thank you. I like to see it.
Thats really nice, I don’t suppose I can have a copy?
It can be downloaded here
http://www.foro3d.com/f27/mis-modelos-124993.html
