Originally shared by Dushyant Ahuja
#VelocityPainting
Vase velocity painted using the latest version of repetier and slic3r prusa edition.
Great results, cool design.
This is the stl. https://www.thingiverse.com/thing:745879
I downloaded a black and white floral pattern from google images and applied it using velocity painting.
Repetier has now included velocity painting as a function. Makes it extremely easy to use.
I tried repetier but i cant get anything to show up right
@Cristian_Martinez a few things to take care:
Try simple patterns.
Check check and check. I used the VelPaint app to add the image to the gcode then used repetier host to verify the gCode snd it showed up fine. Tried the same settings in repetier host and used the built in velocity pain tool and it wouldnt show up anything
That is truly a thing of beauty.
Did you ever try swapping the effect by inverting the speeds?
That was my first try im still figuring this out lol
