Originally shared by D Rob The Hydra with its shroudless direct bolt on fans.
The Hydra with its shroudless direct bolt on fans. The fans just hit the base of the rod clamps on the x/y ends :confused: changing print area to 12 x 11 ⅝. I’m not happy. The STL will be fixed by shaving off 2mm and I’ll file these down so that I don’t have to reprint and disassemble.
Hey @D_Rob , how’s this coming along by the way? Very interested in knowing if you’re running into the same problem that @Tim_Rastall was having with non-straight rods and the rotation causing problems.
Haven’t had time to work on it. I’ve moved and am starting college Monday. Hopefully soon though. I see no visible bend while rotating manually though.
