@igus_Inc 1050 lead screw’s with antibacklash nuts get a new x/y end! Upgrading the UL-T-Slot mkIII. MORE TO COME SOON ! This is the test fit which fit perfectly. I left openings for adjusting the backlash. Works better than i had hoped!. I just hope the pitch isn’t too aggressive or I’ll have top slap 40 tooth pulleys on the drive for x and y
It was the only thing faster than what I’d use on z. I have 1204 on the bot now. Great for machining speeds. Have to use high microstepping and still not as fast as I’d like. So I’m trying these. I can always gear it down via the pulley that interfaces the motor while leaving everything else in place. Better than ball screw’s because they are self lubing and cheaper too.
