The firmware is very close to having the right base to be built upon ( as in : NuttX has finally mostly been beat up into the shape we need ),
and the first ( PRE-ALPHA ) v2-mini protos have just been produced, they’ll be used mostly only to confirm the basic design decisions for the series, and are not expected to print/cut anything for several months still.
@Stephen_Baird It is ! And if we do everything we want to do succesfully, it’ll probably be at a price that will shut up the “I’d buy Open-Source buy China is less expensive” people.
There will be a ton of new features, but they will be rolled out progressively. v2 is all about having the room and power to implement those. Right now we are concentrating on getting v2 to the point v1 is at now.
@donkjr Actually, v1 already has this, it’s just commented out because nobody ever tested it. It’s been there for two years, it’s possible the line was deleted since in a clean-up, but it’s really a 3-lines change. It’s just not activated because nobody ever tested it and we nearly never get requests for it.
@Arthur_Wolf whats the best way to get more info this analog power control and how to use it?
+Wolfmanjm would this be a better approach than the PWM to analog conversion circuit we are working on???
I’m saying changing the laser module from pwm to dac is only a few lines changes ( the pwm and dac objects are very similar ) and years ago somebody did just that ( it was in the code for a while commented … or possibly in a branch ) but nobody ever actually tested it.
@Wolfmanjm is the processor dac not run whatever reference voltage you set up (travelling so I didn’t look up the processor)?
I was encouraging the add of a 0-5 dac or pwm-analog circuit on V2.
