Originally shared by Andrew Hodel Millcrum now includes a 3d viewer which will show
diycnc-software
gplus
(Andrew Hodel) #1
Millcrum now includes a 3d viewer which will show the actual GCODE toolpath as well as the editable side for the Millcrum code.
http://millcrum.com
For this I created a new JS Gcode Viewer called GCView that you can find here - https://github.com/andrewhodel/GCView - It is possible for you to include it in any project with just 2 lines of code.
Enjoy.
(David Kirtley) #2
Your code is looking pretty good. You are a braver person than I am. I looked at that code from Three and I wouldn’t touch that undocumented mess of code. Most projects like that end up failing when nobody else can step in and maintain anything.
