As part of my VG-L7X Engraver project I have been thinking about optical measurements.
I found an optical sensor and a module for that sensor. As usual there either are no schematics or confusing ones available.
It’s a pretty simple PCB so I created a schematic: https://www.digikey.com/schemeit/project/opt101-module-5f5bfbe080b24f45a4dbe1bf695e7914
The project is on the back burner due to other stuff.
I plan to use some form of attenuation like used in cameras or alternately materials with some absorption at that wavelength.
I plan to use some form of attenuation like used in cameras or alternately materials with high absorption at that wavelength.
