It used to be working fine. Then yesterday, I was jogging it around and noticed homing was giving an error. It turned out that my 3d-printed mount for the Z-axis limit switch had broken. No biggie, but rather than print a new one (again) I decided to take a piece of angle iron and make one.
Done! That worked fine.
Note: I did not make any electrical changes to the switch–it was still connected and I just re-mounted it on the new bracket.
I jogged it a little and then I was trying to get it hold its position in between jogs.
I set $1=255 to keep the steppers energized. Done. That was working.
Then I tried to set $1=0 to turn them off. Nope. They stayed on. Was it set to 0? Yep.
So I turned it all off and then back on again. I think I jogged it some more, and then I got a weird halt error. (“ELF” something I think?)
I had to power it off. After powering it on, I keep getting this error.
Note that I would sometimes intermittently get this error connecting in the past, but it usually went away if I disconnected the USB cable, turned off the power supply, and left the BBX32 on to let it drain, then turn it all back on, reconnect the USB and it would connect just fine.
Not anymore. It appears to be working, triggers the USB port being recognized, and looks like it should be working, but it fails to connect successfully and now I’m forever stuck getting this error.
I’m wondering if anybody has seen this problem/error before? Any thoughts/ideas/pointers appreciated. If I can’t work around this, I guess I’ll have to use a new control board.
(aside: I’ll probably try my old TinyG v8 first to see if that works with the better power supply like I detailed in earlier posts, but I’d like to explore making this work before I rip it all apart and toss the BBX32 host controller.)
Error in text form:
[15:19:35] [ 3D Viewer ] WebGL Support found! success: this application will work optimally on this device!
[15:19:36] [ websocket ] Bidirectional Websocket Interface Started Succesfully
[15:19:37] [ update ] Checking for Updates
[15:19:40] [ connect ] PORT INFO: Port is now open: /dev/ttyUSB0 - Attempting to detect Controller…
[15:19:40] [ connect ] Attempting to detect Controller (1): (Autoreset)
[15:19:40] [ connect ] Attempting to detect Controller (2): (Ctrl+X)
[15:19:41] [ connect ] Attempting to detect Controller (3): (others)
[15:19:41] [ connect ] Attempting to detect Controller (4): (DTR Enable)
[15:19:42] [ connect ] ERROR!: No Response from Controller - See https://docs.openbuilds.com/doku.php?id=docs:blackbox:faq-usb-connection-failed for troubleshooting information. Closing port /dev/ttyUSB0
[15:19:42] [ disconnect ] PORT INFO: Port closed
[15:19:48] [ update ] You are already running OpenBuilds CONTROL 1.0.390
[15:21:11] [ interface firmware update tool ] Downloaded firmware.bin v1.58
EDIT: Not that it should matter, but this is on Kubuntu Linux (26.04 LTS), same as it has always been.
