Only a few hours to go and it looks like this can do PWM laser control for greyscale as well as open source g-code senders and even Lightburn. The Kickstarter is amost 100% funded! Looks like an all or nothing kickstarter.
@funinthefalls by spindle driver I mean the motor is driven directly from the board? I noted on kickstarter that the spindle is driven from PPM output?
Thank you all so much ! You all helped me by posting about it which is incredible. Anthony even stayed up till 4.30am, I owe you all. Thanks again, Paul
