On the Eustathios what is the vertical distance between the y and x axis?
@Keith_Dibling 14mm vertical distance between the rods on both Eustathios and HercuLien. So carriages are interchangeable. They would just need the proper misalignment bushing installed for the shafts used on that machine. Eustathios uses 8mm carriage rods, and HercuLien uses 10mm rods.
Thanks Eric
I’m just trying to set up x & y whilst awaiting bearings
