On nearly every job, I see errors returned from the Inventables gShield running GRBL 0.9. Error codes 25 and 33 seem to be the common ones. Often clicking up-pause in Chillipepper is required to get the job to continue. Today the XCarve cutter gouged my part badly after one of these errors. So I guess I need to get to the bottom of it. I use MeshCAM to generate the GCode. My files are typically 3-10k lines. And I am running SPJS 1.86 with Chillipepper.
Another clue - when I send the nc file with GRBL in $C (code check) mode, it seems to parse the file without error.
Is anyone else seeing this? Any solutions out there?
I don’t believe its a problem with the GCode. The file runs fine in $C mode and in several simulators. I’m thinking its a comm error, either a buffering issue or electrical noise.
What if you step through your gcode file line by line? The buttons next to play/pause/stop allow for that and you could possibly debug better. However, what line is it erroring out on? You should be able to see that in the Gcode widget as it puts checkmarks in there when completed.
