On HercuLien, For the feed from the side mounted filament feed unit out to
On HercuLien, For the feed from the side mounted filament feed unit out to the carriage, how did you decide on a length for the tubing? What are the lengths you all are using?
anywhere in the 950-1050mm range I would imagine. My current tubing is around 1050mm, but I could go shorter. You want it as short as possible while still maintaining a gentle arc when the carriage is positioned at back left corner.
@Zane_Baird hit the nail on the head.
Thanks, I will proceed with that length!
