OMTech Laser Gantry align
Hello, I have an OMTech Max-1393 and discovered that it doesn’t cut squares.
So it’s not a mirror issue, but rather a parallelogram being cut.
I’m seeing differences in the diagonal.
I’ve read in some reports that you should loosen the rod at the back of the stepper motor and then you can align it.
But I can’t reach the screws on the laser. There are no flaps that you can open either. Does anyone have any ideas?
First off, with a new machine, contact the vendor.
Most of these are welded on a jig to ensure everything is 3d square. There is limited amount that you can do, such as shimming, but I think the vendor should guide you on how to correct the issue with a new machine.
I know it’s rather a slow process doing this, but it’s the safest way to protect yourself and get your machine up and running correctly. Generally speaking, you need to stay on good grounds with your vendor.
:smiley_cat:
