Old Artillery Sidewinder X1...looking for suggestions
All,
(Do not mind the mess…its the lab…and I always have a number of projects going on in the lab)…
I have this Sidewinder X1, given to me by a family member, that is by no means stock. I believe its setup with a BigTreeTech TFT 3.5 arrangement and I have very limited knowledge of this layout. I have printed a couple things with it (mostly test prints) in the 4-5 years I have owned it (not much been done in 2 years) but originally the main reason for the family member to dispose of it was the prints were just plain inconsistent.
I traced most of the issues down to a number of things in the mount of the hotend/extruder setup which had a series of 3D Printed components holding things together which flexed greatly during printing. A couple rollers which seem suspect (warn) and from memory I switched out the Z lead screw/thread rods as they and the brass holders seemed very warn (clearance between the lead screws and brass holder was apparent). After I did the above I was able to get consistent prints which were fair/decent quality but it seemed I was battling my overall understanding of the BigTreeTech setup. Also at that time (4-5 years ago) I really only had one other printer (my first 3D printer).
Anyways today, at a minimum it needs a serious cleaning, a number of issues with the screen setup, and I noticed there are a number of end stop switches that are just not hooked up. Not sure why and I will probably have to open the case and do some tracing of wires and research on the mainboard. The screen setup currently I just do not like at all. I do not like the screen being external to printer case and I really do not want to cut into the case in any way. I did some prints of some enclosures options but that is where I left things a number of years ago.
I am looking for suggestions on what should I do with this thing today to get it back to printing good quality prints. Should I look more into the BigTreeTech TFT 3.5 setup (and try just using it)? Should/Can I convert this back or over to a stock Sidewinder (X1 or better( X2, X3, X4 upgrade)). I believe going back to the stock Artillery setup, I would have to change the hot end/extruder setup, mainboard, display screen, and possibly cables etc and this would not be cheap to do. I may (I know I would) be better finding a parts unit and fixing it but again I have this printer in front of me. Suggestions, Anyone have experience with the BigTreeTech TFT 3.5 setups, thoughts?
Thanks
Chris
I would first decide do you want something to mess with or something to print stuff. It doesn’t take long to add up to what a new printer would cost that would work way better.
Are you wanting to replace the control board? Isn’t the TFT35 just a display? If you want a different control board it would be a SKR mini or something else or is it working and you just want somehow to mount the display?
Matt,
Thanks for the response!
I agree, its easy to spend about the same amount of money on a project machine, as a new better equiped machine would cost.
I have a number of 3D Printers(8) and I just finished up refurbishing a Sidewinder X2. I do like the larger beds of the Sidewinder and this unit is… well… doing nothing but gathering dust. The larger bed does give it a little leeway on the financial side. It will be my third Sidewinder.
Printing is not a problem for me, so probably something to play (learn more) with is my goal, and I do like the fact I can throw a number of printers at a single project to get things done quickly. Not to mention, set specific machines for specific filaments have been handy in the past a time or two. I also have a large family and the kids are just starting to get the 3D Printing bug as well.
I will be lying though if I said I have little interest in the newer more feature rich printers but its easier to also get rid of a working printer (selling or giving it away even for free) than a non working one.
Anyways, I think its a good point to figure first what is actually in this unit and get some pictures and specs while I clean it. I have been crazy busy with work and family this week and hope to get more on the printer over the weekend.
The family member I got this printer from I believe gave me some of the old original parts for the printer as well. I believe they were mostly mounting items for the hotend etc.
I do believe the most annoying thing is the actual screen setup. Mostly the mounting setup. I have considered designing my own but I have not searched recently on the sites for options/ideas. I believe you are correct the BigTreeTech TFT3.5 is just the display. The setup probably mimics the X2 where there is a mainboard (Ruby) and the Display and USB Board combo.
Next concern is the extra wires that I see loose which one I know is a endstop (Y) and it appears to need just a mounting screw and to be tested. The other is a Z Axis but it appears to be in a state not to be used and maybe the thought was to somehow use the ABL upgrade that the previous owner did. The Sidewinder X2s use both the ABL and the Z Axis min end switch. The other (4 wire setup) goes to the top of the printer and may be related to lighting or that wire may have been bypassed (dead wire) and used for the ABL setup. (from reading and looking quickly at things both are possible).
I will also see if I can get Pronterface connected to confirm operation of the standard components as well. Running a GCode M115 will tell me quite a bit on the setup etc.
From my memory the board that is in it had a custom Marlin build (firmware) on it. I believe, once upon a time, I had the latest source code for the main board firmware (Github). I have the capability/understanding now to rebuild the Marlin code (in VS Code or Visual Studio) if needed. I did not the last time I played with this machine. I found some notes scribbled on the shelf, this thing has been sitting, that said configuration was not confirmed by the previous family member. She just found a firmware for the board (online) and just installed it. So it may not be properly setup for the actual mainboard/printer’s capabilities. So knowing the main board and its setup is a priority.
Honestly I would like to get this thing to print well and to spend what is necessary to do this right. Unfortunately I think at this time there are to many unknowns to say which direction for sure but finding a good mounting setup for the display and knowing what the main board is will give us our direction.
Again Thanks for the response,
Chris
I have the same I have a ender 3v2 that I put klipper on with a different screen and a custom mount, a different extruder, and some other stuff as well as a bambu p1s which always works.
If you have a raspberry pi you could put klipper on it and get rid of the display. I have found klipper is much easier to tweak stuff on than marlin you can just update a text file in the web interface and reboot.
All,
Got some time with the printer today to clean it up and to look under the hood.
The mainboard is a BigTreeTech BTT SKR V1.4 Turbo. It has TMC2209 Stepper Drivers (set for Sensorless homing (MS3).
The display is a BTT TFT 3.5 v3.0 (3.0.27) Display.
The Axis End Switches are all connected to the mainboard but as the sensorless homing seems enabled (MS3 set on Stepper pins) not sure if they are being actually used. This sensorless homing may explain why the end switches are not mounted (loose or turn sidewise). I did a Homing on it and it crashed into the bed and X Axis, but not sure if that is the sensorless homing (normal operation) or some other issue at hand. I am going to have to dig into the sensorless homing, and this setup, to see if its working correctly. This feature is something I am not familiar with to date.
The Printer supported a standard Pronterface connection and all the standard main components seemed to work as the should. (Hot Bed, Steppers, Extruder, and Hot End)
A M115 command returned the following, >>> M115
SENDING:M115
FIRMWARE_NAME:Marlin 2.0.8 (May 8 2021 21:52:10) SOURCE_CODE_URL:github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:Sidewinder X1 EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
Cap:SERIAL_XON_XOFF:0
Cap:BINARY_FILE_TRANSFER:1
Cap:EEPROM:1
Cap:VOLUMETRIC:1
Cap:AUTOREPORT_TEMP:1
Cap:PROGRESS:0
Cap:PRINT_JOB:1
Cap:AUTOLEVEL:1
Cap:RUNOUT:1
Cap:Z_PROBE:1
Cap:LEVELING_DATA:1
Cap:BUILD_PERCENT:1
Cap:SOFTWARE_POWER:0
Cap:TOGGLE_LIGHTS:0
Cap:CASE_LIGHT_BRIGHTNESS:0
Cap:EMERGENCY_PARSER:1
Cap:PROMPT_SUPPORT:1
Cap:SDCARD:1
Cap:REPEAT:0
Cap:SD_WRITE:1
Cap:AUTOREPORT_SD_STATUS:1
Cap:LONG_FILENAME:1
Cap:THERMAL_PROTECTION:1
Cap:MOTION_MODES:0
Cap:ARCS:1
Cap:BABYSTEPPING:1
Cap:CHAMBER_TEMPERATURE:0
Cap:COOLER_TEMPERATURE:0
Cap:MEATPACK:0
area:{full:{min:{x:-3.0000,y:-7.0000,z:0.0000},max:{x:310.0000,y:310.0000,z:400.0000}},work:{min:{x:-3.0000,y:-7.0000,z:0.0000},max:{x:310.0000,y:310.0000,z:400.0000}}}
The Marlin firmware version seems to be the old standard firmware from what I can find online. Might change/upgrade that down the road but I believe I will stick with it while I run it through a couple prints etc.
I reconnected the Y Axis End Switch and verified that the wiring that is hanging loose near the top of the printer is related to a unconnected light bar. Will need to confirm how to put that into a functioning state.
I cleaned the printer inside the main base and everything outside. Used Q-Tip and IPA to clean the small electrical areas and to remove dust in hard to reach areas.
I also lubed the lead screws (threaded rods).
Initial walkthru on the printer points to the sensorless homing and or the end switches possibly being a problem. I also believe sensorless homing has to be enabled in the firmware. My running of the M914 and M122 commads are saying the firmware is compiled with it enabled. The M122 command is returning an issue around the StealthChop. The AI from google suggests I disable it temporarily using the below commands;
M569 S0 X Y ; Switch X and Y to spreadCycle mode
G28 X Y ; Home X and Y using sensorless homing
M569 S1 X Y ; Switch X and Y back to stealthChop for quiet printing
It also suggest increasing the sensitivity to the stepper stalls by a M914 command;
M914 X85 Y65 ; Example: Making X and Y slightly MORE sensitive to stalls
Current X is at 80 and Y is at 60.
Anyone have experience with the Sensorless homing or the above commands. The belts and everything are basically new so I think we could be looking at some tuning and things might get better or further to printing.
Thanks
Chris
