[System]
machine_type = Printrbot Play
[Watchdog]
enable_watchdog = True
[Geometry]
axis_config = 0
offset_x = 0.001
travel_x = 0.1
offset_y = 0.001
travel_y = 0.2
travel_z = 0.116
offset_z = 0.0
[Steppers]
microstepping_x = 6
microstepping_y = 6
microstepping_z = 6
microstepping_e = 6
steps_pr_mm_x = 5.0
steps_pr_mm_y = 7.14
steps_pr_mm_z = 125.98
steps_pr_mm_e = 30.625
direction_x = 1
direction_y = 1
direction_z = -1
current_z = 0.7
current_e = 0.8
current_y = 0.8
current_x = 0.8
slow_decay_x = 1
slow_decay_y = 1
slow_decay_z = 1
slow_decay_e = 1
[Heaters]
E3D v6 Hot end
temp_chart_E = SEMITEC-104GT-2
pid_p_E = 0.0313458514797
pid_i_E = 50.1149661064
pid_d_E = 3.61579842038
ok_range_E = 5.0
max_temp_E = 298.0
temp_chart_HBP = B57560G104F
pid_p_HBP = 0.028372370413
pid_i_HBP = 146.180718708
pid_d_HBP = 10.5469494017
ok_range_HBP = 7.0
max_temp_HPB = 140
[Cold-ends]
connect-therm-E-fan-0 = True
therm-e-fan-0-target_temp = 150
[Endstops]
has_x = True
has_y = True
has_z = True
end_stop_X2_stops = x_cw
end_stop_Y1_stops = y_cw
end_stop_Z2_stops = z_ccw
invert_X2 = False
invert_Y1 = False
invert_Z2 = False
invert_X1 = True
invert_Y2 = False
invert_Z1 = True
[Homing]
home_speed_x = 0.7
home_speed_y = 0.7
home_speed_z = 0.008
home_backoff_speed_x = 0.01
home_backoff_speed_y = 0.01
home_backoff_speed_z = 0.004
home_backoff_offset_x = 0.006
home_backoff_offset_y = 0.006
home_backoff_offset_z = 0.003
[Probe]
length = 0.01
[Servos]
servo_0_enable = False
[Planner]
move_cache_size = 1024
min_buffered_move_time = 100
max_buffered_move_time = 1000
max_speed_z = 0.008
max_speed_x = 1.1
max_speed_y = 1.2
max_speed_e = 1.2
acceleration_x = 0.6
acceleration_y = 1
acceleration_z = 0.030
acceleration_e = 1.5
max_jerk_x = 0.04
max_jerk_y = 0.06
max_jerk_z = 0.006
max_jerk_e = 0.03
[Homing]
home_x = 0
home_y = 0
home_z = 0
[Macros]
G29 =
M561 ; Reset the bed level matrix
M574 Z2 z_ccw
M558 P1
M557 P0 X40 Y80 ; Set probe point
M557 P1 X60 Y80 ; Set probe point
M557 P2 X60 Y120 ; Set probe point
M557 P3 X40 Y120 ; Set probe point
M557 P4 X1 Y80 ; Set probe point
M557 P5 X20 Y80 ; Set probe point
M557 P6 X20 Y120 ; Set probe point
M557 P7 X1 Y120 ; Set probe point
M557 P8 X80 Y80 ; Set probe point
M557 P9 X99 Y80 ; Set probe point
M557 P10 X99 Y120 ; Set probe point
M557 P11 X80 Y120 ; Set probe point
M557 P12 X1 Y1 ; Set probe point
M557 P13 X20 Y1 ; Set probe point
M557 P14 X20 Y40 ; Set probe point
M557 P15 X1 Y40 ; Set probe point
M557 P16 X40 Y1 ; Set probe point
M557 P17 X60 Y1 ; Set probe point
M557 P18 X60 Y40 ; Set probe point
M557 P19 X40 Y40 ; Set probe point
M557 P20 X99 Y1 ; Set probe point
M557 P21 X80 Y1 ; Set probe point
M557 P22 X80 Y40 ; Set probe point
M557 P23 X99 Y40 ; Set probe point
M557 P24 X1 Y199 ; Set probe point
M557 P25 X20 Y199 ; Set probe point
M557 P26 X20 Y160 ; Set probe point
M557 P27 X1 Y160 ; Set probe point
M557 P28 X40 Y199 ; Set probe point
M557 P29 X60 Y199 ; Set probe point
M557 P30 X60 Y160 ; Set probe point
M557 P31 X40 Y160 ; Set probe point
M557 P32 X99 Y199 ; Set probe point
M557 P33 X80 Y199 ; Set probe point
M557 P34 X80 Y160 ; Set probe point
M557 P35 X99 Y160 ; Set probe point
M500
G0 Z8
G28 X0 Y0 ; Home X Y
G92 Y0 X0 ; Reset zero pos
G0 X50 Y100 F8000 ; Move to bed center
G28 Z0 ; Home Z
G0 Z5 ; Move Z up to allow space for probe
G92 Z0 ; Zero the Z axis
G1 X40 Y80 F8000
G30 P0 F250 S ; Probe point 0
G0 Z0
G1 X60 Y80 F8000
G30 P1 F250 S ; Probe point 1
G0 Z0
G1 X60 Y120 F8000
G30 P2 F250 S ; Probe point 2
G0 Z0
G1 X40 Y120 F8000
G30 P3 F250 S ; Probe point 3
G0 Z0
G1 X1 Y80 F8000
G30 P4 F250 S ; Probe point 4
G0 Z0
G1 X20 Y80 F8000
G30 P5 F250 S ; Probe point 5
G0 Z0
G1 X20 Y120 F8000
G30 P6 F250 S ; Probe point 6
G0 Z0
G1 X1 Y120 F8000
G30 P7 F250 S ; Probe point 7
G0 Z0
G1 X80 Y80 F8000
G30 P8 F250 S ; Probe point 8
G0 Z0
G1 X99 Y80 F8000
G30 P9 F250 S ; Probe point 9
G0 Z0
G1 X99 Y120 F8000
G30 P10 F250 S ; Probe point 10
G0 Z0
G1 X80 Y120 F8000
G30 P11 F250 S ; Probe point 11
G0 Z0
G1 X1 Y1 F8000
G30 P12 F250 S ; Probe point 12
G0 Z0
G1 X20 Y1 F8000
G30 P13 F250 S ; Probe point 13
G0 Z0
G1 X20 Y40 F8000
G30 P14 F250 S ; Probe point 14
G0 Z0
G1 X1 Y40 F8000
G30 P15 F250 S ; Probe point 15
G0 Z0
G1 X40 Y1 F8000
G30 P16 F250 S ; Probe point 16
G0 Z0
G1 X60 Y1 F8000
G30 P17 F250 S ; Probe point 17
G0 Z0
G1 X60 Y40 F8000
G30 P18 F250 S ; Probe point 18
G0 Z0
G1 X40 Y40 F8000
G30 P19 F250 S ; Probe point 19
G0 Z0
G1 X99 Y1 F8000
G30 P20 F250 S ; Probe point 20
G0 Z0
G1 X80 Y1 F8000
G30 P21 F250 S ; Probe point 21
G0 Z0
G1 X80 Y40 F8000
G30 P22 F250 S ; Probe point 22
G0 Z0
G1 X99 Y40 F8000
G30 P23 F250 S ; Probe point 23
G0 Z0
G1 X1 Y199 F8000
G30 P24 F250 S ; Probe point 24
G0 Z0
G1 X20 Y199 F8000
G30 P25 F250 S ; Probe point 25
G0 Z0
G1 X20 Y160 F8000
G30 P26 F250 S ; Probe point 26
G0 Z0
G1 X1 Y160 F8000
G30 P27 F250 S ; Probe point 27
G0 Z0
G1 X40 Y199 F8000
G30 P28 F250 S ; Probe point 28
G0 Z0
G1 X60 Y199 F8000
G30 P29 F250 S ; Probe point 29
G0 Z0
G1 X60 Y160 F8000
G30 P30 F250 S ; Probe point 30
G0 Z0
G1 X40 Y160 F8000
G30 P31 F250 S ; Probe point 31
G0 Z0
G1 X99 Y199 F8000
G30 P32 F250 S ; Probe point 32
G0 Z0
G1 X80 Y199 F8000
G30 P33 F250 S ; Probe point 33
G0 Z0
G1 X80 Y160 F8000
G30 P34 F250 S ; Probe point 34
G0 Z0
G1 X99 Y160 F8000
G30 P35 F250 S ; Probe point 35
G0 Z0
M561 U
M561 S
M500
M574 Z2 ; Disable Probe
