Ok so I have a bit of an odd problem.
Ok so I have a bit of an odd problem. I just installed a induction sensor on my Printrbot plus and it seems to work, however the printer instead of going from the front corner then the front right corner and ect. the printer just goes to the center of the build plate stops and goes down and seems to work fine. I have already tried adding G29 to my start Gcode in Cura and other than that I’m not sure what to do. I hope someone knows how to fix this multi day problem I’m having.
Do you call G28 X0 Y0 right before G29? If not, I recommend to do so.
I do call g28 before g29.
I would check if Printrboard has the most recent firmware version. Also, a video of what’s happening would help to diagnose the issue.
