Ok, I am inching toward going the Smoothie LaserWeb route for my K40 replacement controller.
I have a few remaining questions that are keeping me from completing my conversion design and I am sure there are answers on this forum somewhere, so I apologize for the annoying repeat.
In any case I plan to keep looking until I get my conversion designed and then plan to document and share this adventure for the next explorer.
I find that there is a lot of information but not necessarily in one place nor synced with my model (if K40 has such a concept) machine.
In regards to the smoothie conversion from my K40 with M2Nano:
- Does the K40 DC supply have enough 24 and 5V capacity?
- Has anyone had to replace laser power supplies to get good PWM control and what supply did you use.
- Does it support a rotary table and if so what one? Do I unplug the Y stepper and plug the rotary table into that connector?
- Anybody converted optical endpoint sensors that I can reference for my conversion. Probably will use a middleman board.
- What is the story on engraving support from what I can see it doesn’t? What if I want engraving also :)?
- Has anyone been using Sketchup with this setup?
- Does it support a Z table and if so can you operate it from the display panel/LaserWeb. I have a LO lift table that is standalone.
- I see that you can connect to SSR’s from the base board. Can you set it up so these relays turn on a specific general times like, before and after cutting?
- Is there an interlock circuit that I can use for water flow, water temp, lid interlock etc and does this function stop the lasers operation.
I will eventually answer all these but any help is appreciated … my final design will document all the answers and be posted.
