Ok here is the list of things I will be purchasing as soon as
Ok here is the list of things I will be purchasing as soon as I hear some feedback on whether I will need anything else.
Also this will be in an unheated workshop. Can I put some antifreeze in the water for the spindle to keep it from freezing?
Thank you for all your help.
Eddie
R7 CNC DIY Kit
Add on options:
TinyG Controller: Yes
Drill and Tap everything: Yes
Ceramic Screw Driver
3.175 mm (1/8 inch) CNC engraving bit set
Emergency STOP Switch
V carve pro
Dust collection system
Yes, you want at least 15% for corrosion protection as well. If you run into construction questions post. The instructions assume you have watched the videos which I never watched.
Hey Thanks @Colin_Kaminski . You have been a very big help.
OK, The trigger has been pulled. The order is complete. Hopefully it will be up and running by Christmas.
The R7 has been shipped. It will be here on Tuesday. That means the table will have to be built this weekend. I think I am going to build the table out of 3x4s. Once I mount the cnc to the table I think I will cut out the work area. As far as I understand when you mount the cnc to the table it has a -30 z. So I will cut that out and then cut a waste board to fit. this way if I need to carve something taller than the +90 I can just take the waste board out. Does that make sense to anyone?
