End of prints I always hit ‘Home X’ then with the Y and Z
Everytime I hit ‘Home X’ the extruder moves to the left about 10mm then stops. I hit it again and it repeats. I hit ‘Home Y’ it goes right where it suppose to and so does the Z.
Check the wiring on the X axis sensor. The way the X axis sensor wires are on the DaVinci, they take a lot of abuse. I found that mine was not cut, but there was a weak point that created a short so it sometimes worked and sometimes didn’t. I ended up soldering the spot, but a month after that it did it again. Right now, I have not fixed it and don’t use the Home X function. I just manually move the extruder over. My Z and Y homes all work fine.
