Ok Brook Drumm I'm chomping at the bit to print with the spools of
Ok @Brook_Drumm I’m chomping at the bit to print with the spools of ABS I have lying around (haven’t used them since the destruction of my Prusa). You have anymore photos or video of the new heated bed for the metal simple? I must see more!!! I need to feed my customizing hunger! Also, how’s the CNC project going?
@Shauki prints on an unheated bed, using double sided tape, it’d be a cheap experiment for you…
Alirubber will make whatever you want and customize power specs @Shauki
So by the 6x6 heater from PB. Get the thermister too. they both plug right into the printrboard. I used hi-temp gasket RTV to glue it to the bottom of my bed. ABS works great.
Totally an option. I was speaking more on the line of I just want to see more of the official solution. :slight_smile:
