ok 10 stepper arrived.
can start to make pulley for it :slight_smile:
Will You make rubber pulleys like original #motediusqr or my modification with aluparts?
Have rubber but not are sure to make centered hole :slight_smile: …but want try it in case go on gt2 belt (max soon need request you a pair of he :slight_smile: )
ok, I have got already one HE in labor. I look for this rubber parts: http://www.ebay.de/itm/271283793777?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
but these need the alu support the already centered ( :wink: ) hole is 12mm.
and, Manco… GT2 belts are not created for speedy movements. HTD 3M are better, but expensive. Look for the pulleys on robotdiggs, the quality is perfect, the price is low.
issue no have lathe in lab too :confused: big issue grrr…need make hole with colum drill…i think make a mask in abs and use it make hole…
max to have are a toys lathe O_O
http://www.bestincn.com/upfiles/Metal-lathe.jpg
I have a new design of pulley in my brain… without rubber, without timing belt… zero backlash and never slipping. I tell and show it within this week.
