Now speed and rotation controlled from g-code. I am using a second serial port for the VFD control with an Arduino Mega runing Marlin firmware. You can see the M3/M4/M5 commands in the center window.
https://vimeo.com/109340551
Marlin does not support M3-M5 commands but grbl does. The problem with this matter is that each VFD is different so it won’t work with a different hardware. Secondly, grbl is kind of tight code-wise so this might not fit because, thirdly, an additional serial port is needed (which Arduino UNO lacks of, and the software serial library will require even more code).
So I am afraid it may be a tough sale for grbl maintainers. Things change, however, if you use grbl on an Arduino Mega with plenty of free space for additional code and three additional serial ports.
Anyway, you can use my code freely http://pastie.org/9660347
+Peter van der Walt No, I am using Marlin on a single Arduino Mega for controlling a CNC. Marlin is designed for 3D printing but it works for me and it offers 40Khz pulse rate. I am using Serial2 with a RS485 driver for controlling the VFD and Serial0 for USB comms.
I can see one Arduino UNO board that shows on the top right corner of the video, but that one is just lying on my table and not connected in this case.
Miguel. Do you think using a beagle bone + cramps is a good idea for a CNC
Which drivers r u using on your current CNC
Does marlin support all the grbl g codes
@Janardhan_Raju No, it does not, but being open source it means you can add commands as you need them
@Janardhan_Raju Sorry, I missed this question of yours: I am using M542 drivers http://www.leadshine.com/UploadFile/Down/M542d.pdf
