Nothing is true, everything is permitted
Nice! Source?
I got it from thingiverse, I had to scale it down though hence the quality not being too great
Nice! What printer , material and did you use supports? Thanks for info
It a hollow print with supporting using 3mm ABS and it was printed on a prusa mendel and a 0.5 nozzle.
Nice cleanup of the support. Did you use slicer or kiss?
@Eric_Moy I used slic3r but I’m not that impressed with the support feature tbh
I haven’t played with the settings much yet though .
EPIC!!!
I’ve only printed PLA with slicer support. It’s awful. I use maker ware and abs at work and it’s sooooo much easier to remove
@Eric_Moy yeah, I’ve tried PLA with support, never again. I have a few better options but I’ll need a dual extruder to pull those off
