Not sure whether this is a FABkit, Smoothie or LaserWeb4 issue…
I have this fairly simple project, and previous larger versions cut fine, but this one stops when it goes from the ‘inner cut’ (the 2 ovals and the lines for the live hinge) to the ‘outer cut’ (the rounded corner rectangle around it all) activity…
The laser just stops moving, but the compressor for air assist remains on.
No errors in the LW4 window either!
So it doesn’t reach the end (or the head would move home, and the compressor would cut out), it just stops processing the gcode, apparently!
