Not really certain where to put this,
Not really certain where to put this, but it’s an addon script for Adobe Illustrator to automate the process of adding dimension measurements to shapes/objects within images.
Originally shared by Yuusuf Sallahuddin (Y.S. Creations)
For anyone using #Adobe #Illustrator when you want to get dimensions onto shapes in an image is a painstaking process to do it manually.
Just found this script that automates the process & makes it a lot less time consuming.
http://adamdehaven.com/blog/2015/05/dimension-adobe-illustrator-designs-with-a-simple-script/
I’ve made some modifications to this addon, to fix this Issue: https://github.com/adamdehaven/Specify/issues/3
So, my post in the comments has the fix as a .txt file (you can either copy & paste it’s contents into the original .jsx file or rename it to Specify.jsx). This will enable to choose which sides to get dimensions for (via checkbox) & can do all selected sides at once, instead of having to manually do 4 times for 1 object.
Update on this… there is a new (much more improved) version available now. https://github.com/adamdehaven/Specify
