News no news.
Clipper is great lighter. … made in Spanish(Bic china) all disasessamble without destroy(Bic destroy it and no chance to reuse)…for example for extract wheel need only lock gear and rotate aluminum star…
Defect have 3mm hole…both version have same wheel…mm if drill it I think kill bit…any suggestions?
@shauki is the right guy to ask… I would give it ago. Even if you don’t get the hole perfectly centered, the current #saintflint design should accommodate it nicely, it will just dance a little!
Ooops! @Mauro_Manco should have read this before letting go his precious €€€:
http://clipperukltd.co.uk/counterfeit.pdf
Lost for loss, maybe the fake one is more ductile… Worst case you lose a drill bit.
checked original clipper…all part are same pdf…
Shauki find honest seller and lose 2 euro… emm 1…because one woking…
I’ll try to get my hands on one here in Portugal to see if there is a difference.
Those from @shauki are apparently quite old. Maybe they see us coming and the production is now with a different diameter.
That’s creepy. Will you still try to make a fireworks at home with your not-too-large-not-collector flint wheel? LOL
no drill …flint more strong of dlill bit it burn…
Flint Wheel - 1 / Mauro - 0
:% now find stepper with 2.8 mm shaft
WIN…DIAMOND BITS DESTROY FLINT MAKE HOLES 3.14 (DREMEL TOOLS) NOW NEED FIND DIAMOND BIT 5MM
I killed 1 diamond drill also. i have left only a spherical on to try, or find a small conical file
Whaouh! What are you complaining about… Finding loose diamonds when doing some 3D printing. Wife will not complain for sure!
Joking aside, this tells a lot on the durability of this stuff!
small…durability feel really small…max 2 flint.
@Mauro_Manco Just bought 2 3 pack mini lighters for $6 USD…that’s about the same unit cost.
