New To Maker
Been a software engineer for some time now (web space).
Enrolled back in school for a dual degree:
A.I. & machine Learning, With Digital Maker/Fabricator
Ive also incorporated a variety of robotics classes, electronics, etc.
So far I am only halfway through.
Question
My goal is, to set up my own workshop/maker space “if that’s what it’s called?”, in my garage.
I want to be able to build/fabricate, my own IOT products.
I have no CNC Eperience (plan to get training)
No Woodworking Experience (plan to get training)
My question is:
What supplies/machines/etc. Should I plan on purchasing to set up a decent shop? With budget of $25k to $50k total. Sqft available 700sqft
3d printers, CNC machines, etc. ?
I assume that you already know about the Electronics side of things… ?
For making cases etc I’d start with a ready-to-go 3d printer setup, something like a Bambu machine that will ‘just work’.
  • That’s possibly all you need to start. :wink:
  • Maybe get two, a FDM (filament) machine, and a Resin printer
  • I see lots of people making a case body out of FDM, but all the details, faceplates and buttons using resin.
Adding a small (diode?) laser cutter / engraver should be next, this lets you make faceplates etc. A CO2 cutter, while expensive and complex to run and maintain, allows easy acrylic and ply/wood cutting. Useful for cases, display stands, and a whole bunch of signage.
A CNC is also good, but for ‘IOT’ device making I think a 3d printer is going to be the way to get 3d shapes…
PS: Think about ventilation; especially if you have any form of laser cutter, but also for 3d printers and soldering fumes.
This will poke the hornet’s nest.
I have all the CNC types and three CAD software tools. I have found that these are great if you make more than 2 of a project. With the right skills and manual tools you can get to prototype very fast…
So here is a low-tech perspective of how I package my electronics projects.
You are right my CAD machines are quite lonely!
For one-of-a-kind projects, I typically build from:
  • Acrylic sheet
  • An AC box of some sort from Lowes.
  • A prefab enclosure.
I design with graph paper or CAD depending on how complex the project is and if I need a 3D perspective.
I tested: modeling and machining with CAD/CAM vs hand-drawn and machined.
The latter was faster most of the time. That said maybe I just suck at automation.
I found modeling and then getting the CAM machining to do what I intended, time-consuming.
I have honed three things to enable making enclosures etc from acrylic. Some are not that intuitive:
  • Drilling techniques
  • Cutting techniques on table saw and scroll saw
  • A DIY acrylic bender
  • Slotting on a hand mill.
A remote hottub temp sensor in an adapted waterproof power junction box:
A PID temp controller for my coffee bean roaster project.
A thickness measuring tool project designed to fit in a Polycase enclosure.
A non-electronics project. Replacing a latch in my RV.
This is perfect. Thank you very much!
I noticed you said “product” not “project” — is your goal here to do production work, where you are setting up to make high quantity multiples of a product?
Or is your goal to make a prototype shop as you work towards bidding out production for commercial work?
Do you expect to work with metal?
If you’re interested in setting up a metal shop, I recommend looking for the Blondie Hacks on YouTube and find her video about setting up a home shop. I’m with the other comments on here that if you’re making metal parts for prototypes then get a small manual mill and lathe and learn them first, then add CNC as you need it.
A good 3D printer and laser engraver goes a long way, too.
