If I had $4000.00 that I did not know what to do with, I would buy one of these! Interesting twist on a table saw.
https://www.toolsofthetrade.net/power-tools/corded-tools/mafell-erika-push-pull-saw_o
Not sure I see the value of the blade moving vs wood moving?
Needs less clearance space in front and behind the saw?
It seems to act like two saws in one, miter and table. You can also cut larger items in less space.
Cutting a sheet of plywood … mmmmm.
Things I have learned about woodworking tools:
I’ll stick with moving the wood using the miter track :).
