Also the honeycomb table is huge, it’s not 300x200mm…as advertised…it made to change out the whole insert that is inside the x,y frame.
@Scott_Thorne I also ordered a lens from LO. The high quality 18mm 50.8, so was curious. I should have mine Mon or Tue also, guess I will know soon if it makes any difference.
Keep me posted Marc…
If you will…I’m also very curious.
Any updates on the difference between the lens?
The 18mm lens seems to cut and engrave a lot better at lower power…I’m very happy with it @Sean_Cherven
So that stands to reason that a larger lens will provide a little bit more power (wider beam path convergence) …
@Ashley_M_Kirchner_No …I agree completely…I’ve experienced the difference first hand my friend and its a big difference…that’s only my opinion…others may vary…Lol
