Need to do a tiny bit of touch up sanding. Can’t wait to see it with a coat of poly.
That is amazing work! Are you doing the designs yourself, or where are you getting them?
@Mark_Leino I wish I could design these myself. I have been searching for STL files on the internet. You can find many free ones. eBay has quite a few fairly cheap also. Search “artcam 3d STL” on there.
@Jack_Daugherty If youd be willing to share the design, Im sure there are several people who would love to have it, Myself included…
@Jack_Daugherty You are killing it bud!! Mind if I share your work? Started a group of images from guys that can hammer out greatness like you over on FB.
I’ve also found it easy to pull stuff off of thingiverse , big group of STLs mainly for printers but easy enough to modify.
@Brandon_Satterfield Thanks. I don’t mind at all if you share. I have been finding awesome free 3d files all over the internet. I don’t have enough hours in my lifetime to make them all, lol. I’ll have to check out the FB page.
@Michael_Durie Most of the STL files are too large to send without a file host. A quick Google search will be your best bet.
These are turning out great
@Kelly_Burns Thank you.
That looks great! What bit and speed are you using?
@Michael_Forte Thanks. I’m using a 1/4" up cut 2 flute end mill for roughing pass. 1/8" ball nose for finish @ 60 IPM. I never reach speeds even close to that though because of all the details in the cuts. The step over is 10%. A long process, but it is what it is.
What software did you use?
@Awesome_Coder Vectric Cut3D.
