It’s 40w co2 laser and I think it’s a K40 from China. I got it from granpa, and I think it’s been over 15 years.
As it is an old equipment, I have a PC with Windows 732-bit installed, can I get a compatible driver?
I think the drivers say Philips LPC214X, but I can’t find a compatible driver.
I’m thinking your grandpa had made some modifications to that because 15 years ago they didn’t come with drag chains nor air assist and it looks like the working area has been expanded to around 12" x 9" by removing the stock bed and trimming the exhaust vent.
Update: I stand corrected, the 32bit ARM NewlyDraw 1.5 controller preceded the M2Nano.
Also, they came with M2Nano controller boards and that one with the LPC214X is way more powerful. Have you connected up a USB cable and opened a terminal window to see what firmware it reports? Usually the firmware will report it’s version info on power up but you’ll need a terminal window open, set to the port and with the correct port speed( 9600 or 115200 ).
Another option is to make a bootable USB thumbdrive of something like Lubuntu ( Linux ), boot from the USB thumbdrive in Live mode, connect to your WiFi network and install gtkterm.
But ya, if Windows can’t connect to it and that’s all you’ve got then you’re stuck without those drivers. history: Linux LiveCDs became popular 20+ years ago just for fixing Windows with the Knoppix distribution. Many used it to fix corrupted MS-Word documents using OpenOffice on Knoppix.
