My first usable part on the printer. I did not get a chance to modify the V2 spider Viki2 mount but I will eventually adjust it to fit the Herculien.
Great job. I never though of using that there
Great idea.
I see you are fighting the dangling wire & tube issue I used to. I found a coat hanger wire in the front right corner hole in the vertical extrusion going up about 2/3 the way makes for a nice guide for the bundle.
Keep it up.
Yup that spring wire helped out a lot and it was simple to install.
