LaserWeb information
On the About page, I see that I have:
- Frontend version: _____________
- Backend version: _____________
My settings are:
<go to Settings / Tools and save your LaserWeb Settings to a json file,
then open that file with a text editor and copy/paste the content here>
“settings”: {
“__version”: “4.0.998”,
“__selectedProfile”: “*gen_grbl”,
“latestRelease": “2019-11-26T10:42:57Z”,
“showMachine”: true,
“machineWidth”: 400,
“machineHeight”: 500,
“machineBeamDiameter”: 0.2,
“machineBottomLeftX”: 0,
“machineBottomLeftY”: 0,
“machineFeedRange”: {
“XY”: {“min”: 1, “max”: 50000},
“Z”: {“min”: 1, “max”: 50000},
“A”: {“min”: 1, “max”: 50000},
“S”: {“min”: 0, “max”: 30000}
“machineXYProbeOffset”: 0,
“machineZEnabled”: false,
“machineZMatThickness”: 0,
“machineZToolOffset”: 0,
“machineZStartHeight”: “”,
“machineZProbeOffset”: 0,
“machineAEnabled”: false,
“machineBlowerEnabled”: false,
“machineBlowerGcodeOn”: “”,
“machineBlowerGcodeOff”: “”,
“pxPerInch”: 96,
“forcePxPerInch”: false,
“dpiBitmap”: 300,
“toolGridWidth”: 400,
“toolGridHeight”: 300,
“toolGridMinorSpacing”: 10,
“toolGridMajorSpacing”: 50,
“toolSafetyLockDisabled”: false,
“toolCncMode”: false,
“toolImagePosition”: “BL”,
“toolUseNumpad”: false,
“toolDisplayCache”: false,
“toolUseGamepad”: true,
“toolCreateEmptyOps”: true,
“toolVideoDevice”: null,
“toolVideoPerspective”: {“enabled”: false},
“toolVideoLens”: {“a”: 1, “b”: 1, “F”: 1, “scale”: 1},
“toolVideoFov”: {“x”: 1, “y”: 1},
“toolVideoResolution”: “1080p(FHD)”,
“toolVideoOMR”: false,
“toolVideoOMROffsetX”: 0,
“toolVideoOMROffsetY”: 0,
“toolVideoOMRMarkerSize”: 20,
“toolWebcamUrl”: “”,
“toolFeedUnits”: “mm/min”,
“toolTestSValue”: 1,
“toolTestDuration”: 0,
“gcodeStart”: “G21 ; Set units to mm\r\nG90 ; Absolute positioning\r\nM4 S0 ; Enable Laser/Spindle (0 power)\r\n”,
“gcodeEnd”: “M5 ; Disable Laser/Spindle\r\n”,
“gcodeHoming”: “$H”,
“gcodeGenerator”: “default”,
“gcodeToolOn”: “”,
“gcodeToolOff”: “”,
“gcodeLaserIntensity”: “S”,
“gcodeLaserIntensitySeparateLine”: false,
“gcodeSMinValue”: 0,
“gcodeSMaxValue”: 1000,
“gcodeCheckSizePower”: 0,
“gcodeToolTestPower”: 0,
“gcodeToolTestDuration”: 0,
“gcodeConcurrency”: 2,
“gcodeCurvePrecision”: 0.1,
“comServerVersion”: “4.0.136”,
“comServerIP”: “localhost:8000”,
“comServerConnect”: false,
“comInterfaces”: [“USB”, “ESP8266”, “Telnet”],
“comPorts”: [
“comName”: “COM5”,
“manufacturer”: “wch.cn”,
“serialNumber”: “5&1fd1ce84&0&1”,
“pnpId”: “USB\VID_1A86&PID_7523\5&1FD1CE84&0&1”,
“locationId”: "Port#0001.Hub#0003”,
“vendorId”: “1A86”,
“productId”: “7523”
“comAccumulatedJobTime”: 474,
“connectVia”: “USB”,
“connectPort”: “COM5”,
“connectBaud”: “115200”,
“connectIP”: “”,
“jogStepsize”: 10,
“jogFeedXY”: 1800,
“jogFeedZ”: 300,
“macros”: {
“*GotoXY0”: {
“label”: “Goto XY zero”,
“gcode”: “G0 X0Y0”,
“keybinding”: “ctrl+f1”,
“_locked”: false
“*LaserOff”: {
“label”: “LASER OFF”,
“gcode”: “M5”,
“keybinding”: “ctrl+f2”,
“_locked”: false
“uiFcDrag”: {“x”: -2017.3447983184178, “y”: 720.0998949024203},
“toolUseVideo”: false
Problem description
When I _____, I expect _____, but instead _____ happens.
This problem is new since _______ | has always happened.
Here is sample gcode that demonstrates the problem
<paste the contents of the gcode segment here>
System description
My machine is a diode laser
I have a NAME_OF_CONTROLLER_BOARD
It has NAME_OF_FIRMWARE version VERSION_OF_FIRMWARE installed
I connect via USB |
My computer(s) on which I run LaserWeb run(s) | Windows version ________
Here is my configuration:
<paste the contents of your machine configuration file or $$ output here>
GCODE START
GCODE END
GCODE HOMING
$H
TOOL ON
TOOL OFF
