More Morpheus Delta prints.
Here are a few more prints that came off of the Morpheus Delta.
Please Note:: This is my first resin printer, so imperfections and failed prints could be due to me and may not reflect the capabilities of the printer.
When they started their KS project, the LCD had a very coarse pixel size (~0.19 mm), so it won’t print a high resolution print considering today’s standard (0.047~0.075 mm). Can you confirm your Delta still has a low resolution LCD panel? It seems like they promised 800 x 480 LCD panel on it.
@Yun_H_Jang How can I verify the resolution?
What software are you using for slicing? During slicing there should be a parameter about the resolution.
@Yun_H_Jang In the settings the projector is set at 1280x720. and the x-y resolution is 120 microns.
@PrintinAddiction Then at least they have put a slightly better lcd panel than promised. However It’s very unfortunate that most of other backers except very few don’t and won’t get their printers.
Killing killers
