Has anyone successfully used an MKS DLC32 with an Atomstack M50 A5 Pro?
My LaserBox ESP32 v1 seems to have died, so I’m looking for a replacement motherboard/controller board.
I just successfully replaced the motherboard of my Atomstack A5 M50 Pro with an MKS DLC32 v2.1 with TMC2209 stepper drivers. Pretty much plug & play, except for one required modification: the TTL wire was connected through the plug to the V (Voltage) pin on the MKS DLC32 instead of the S pin (and to make it more difficult, the plug didn’t fit), so I removed the JST connector and replaced it with a Dupont connector.
Everything connected, adjusted the VREF of the stepper drivers to ~80, sent a few commands via LightBurn, and the first engraving test could already begin. Successful ![]()
