Mitigation for early revision of x carriage design - https://github.com/speedy-beaver/Talos3D-Spartan---E3D-Support
@Daniel_Seiler Thank you so much for sharing that. Would you mind if I added it to the Spartan’s Github?
@Alex_Lee Let me try to send you a pull request during the week. If I fail, just take it and add it.
@Chris_Kelly I’m not sure if any firmwares support the loading and unloading of filament. But one way to accomplish that is to create a little custom code to load and another to unload the filament. Are you using Repetier host?
@Chris_Kelly Cura. I can’t verify it from work, but some controller software allow you to create a macro (in your case a macro to load and another to unload the filament) and run the macro with a simple button click. I’ll try to get you an answer later tonight when I’m home from work.
