RESOLVED
…missing dependency (pyusb)
Laptop (that this was 100% working on) decided to die on me (hard drive starting to go bad), so I had to set up on another laptop while I wait for a replacement hard drive in the mail. Got everything setup per the usual instructions, but running into an issue that gives the error “global name ‘usb’ is not defined”. running from command line, I get “Unable to load USB library (Sending data to Laser will not work.)” right before the gui shows up for k40 whisperer. Google searches have turned up nothing so far. Any suggestions on what I need to fix here?
Running in a Linux environment.
