I need your assistance, please. I want to start cutting larger layouts and when I tested the location of the head of my 6040 K40 CO2 laser running on Meerk40t I discovered that there is an offset difference both horizontally and vertically between the screen display work area and the location of the laser head.
Could you be more specific please? Is this a constant offset, or one that is proportional with the position, ie for 2 inches it is less noticeable than at 20 inches.
For the first case you could define an offset value in the laser settings, for the second case you could define a correction factor.
So draw/burn a 10x10 inch rectangle and measure the length of the sides, the ratio between measured and expected length is your correction factor then.
Sorry for the poor explanation, I meant that the physical location of the laser head is not the same as on the location on the screen. In other words, if I make a dot on x:y at 0:0 the actual position is at x:y 10:25 for example.
This difference looks like it is standard across the full size of the bed.
It is now a little more clear, but as with your previous questions, some pictures or videos would assist a lot as would some units-of-measure i.e. is 10:25 10microns,10microns 10/1000",25/1000", 10mm,25mm, 10miles,25miles?
But assuming that this is mm, and that you did a Home in MK before moving the head, then the explanation is that your physical origin is in the wrong place.
So, your scale is off then, afaics. Home your device, fire the laser, either via the physical laser panel or meerk40ts panel, move to meerk40ts 0,0 and fire again. Measure the physical distance between these two points and divide the virtual distance, ie your laser bed width by the measured distance, that’s your x scale factor.
If necessary do the equivalent for y.
