@Michael_Memeteau for no Bic drive what we think?
I’m not following you here… What do you want to use it for? Securing the coil? The minimum radius is too large to fit on 5 mm shaft… I must be missing something.
sorry post fast. i thinking about big gear when saint ring no fit, this are a valid alternative with pressure regulation.
Now I get you… To be used instead of the ring. Actually it’s very easy for me to change the diameter to adapt it to other gear alternative. Could probably do the whole serie from 7 to 12 mm (did it yesterday for @Darkberg_Aryavis in 5 min top).
A zip tie is another alternative, but yes, you’re right, that would work… But not so beautiful, don’t you think?
Also, no wonder you’re having trouble drilling the flintwheel and finding diamonds: the flint is actually a stone…
;)) think we should try concrete drill:) … joke Mauro i can send some if needed. Thx @Michael_Memeteau for the clarification and for the moded part
