Meerk40t: Misaligned entry points on Longer Ray5 10W
​Hi guys,
​I’m relatively new to laser cutting and engraving. I have a Longer Ray5 10W and I’m using Meerk40t, but I’m experiencing some issues. The main one is that the laser misaligns objects at the entry point.
​In my current project, I have three identical objects, but the laser fails on two of them (even though the settings are exactly the same).
​Does anyone have any idea what I might be doing wrong or how to fix this? Thanks
Not sure, I am recognizing the issue here. You speak about three identical, I see four. Could you mark the correct one(s) and the deviating ones.
Sorry about that, you are right. I meant to say four. Regarding your question, I am sending a new image showing the defect. The ones with the green marks are OK. On the others, you have a black arrow pointing to the defect.
Thank you for your help.
