- Correct several small Make Raster bugs where black was preferred over white for transparent.
- DXF, color BYLAYER reading. #357
- DXF ACI corrected.
- DXF Block Reading #357
- Mouse Wheel Pan mode in Settings.
- Modifier Tweaks for Mouse Wheel Pan. Shift axis invert, control zoom.
- OSX magnify mouse trackpad pinch-zoom.
- Added Touch Screen Support (wx4.1)
- Added hard \n in About window.
- Backported Linux LibUSB Windll corrections.
- Fix Camera Interface post-close crash #366
- Added Step & Repeat to Jobs.
The step & repeat is nice, if you’re doing a large grid and you want to do the same thing over and over in a grid pattern. 0.7.0 is still being actively worked on. 0.6.x is supposed to mostly be bug fixes and some stuff that there’s no way to do properly.
