Maker Forums has updated Guidelines (formerly called "FAQ") for LLM usage
The Guidelines have been updated to describe acceptable use of LLMs to interact with Maker Forums.
All use of Maker Forums intermediated by any form of LLM, using MCP or otherwise, must follow those rules.
This does not apply to posting about use of any form of AI, LLMs or otherwise. Humans may use tools, and may have differences of opinions about tools. This rule is strictly about using LLMs to interact with people on Maker Forums.
Please remember that Maker Forums is for humans. LLMs are a tool that can help people or help abuse people. Maker Forums is not a place for humans to use LLMs to be hurtful to other humans.
If you use an LLM to interact with Maker Forums, via MCP or otherwise, it must obey the rules at llms.txt, and failure to do so will be grounds for permanent suspension of all site privileges.
The llms.txt instructions are human-readable. They may be updated from time to time with or without notice and LLMs, whether using MCP or otherwise, are expected to refresh on a timely basis, and follow current requirements.
This should not be a significant burden on the community; the rules are generally aligned with what the community here has already done. However, we are finding it necessary as moderators to take action against this form of abuse. Therefore, we are being clear about the rules so that when we take moderation action, we will be able to do our best to follow our own guidelines in doing so.
