i used a APM 2.6 set with GPS and power module from ebay (70euros), Engine set from DIJ E310 (Motors, ESC, Props and powerboard) (170euros) and a 3S 3300mAh LiPo (SLS)
RC: Jeti RC-easy copter and DC-16
todo: jeti telemetrie (mav2duplex) and BT-module, just waiting for a cable
total lift-off mass: 1.37kg
Frame aprox 550g (only 3D printed stuff)
aprox 50g of screws (V2A)
Lipo 285g
Elektronics+Motors+Cables 485g
thnx
i added some details what i used here and also on my thingiverse page
the E310 set from DJI seems to be sufficient, but similar propulsion would do too i guess. regarding flight control its up to you, i used APM which just fits. Naza would fit better i think but i did not want to spent 300euros on it
Super!!!
Can you share the link of the ebay seller that you bought the apm ? my naza controller is malfunctioned and i am thinking of switching to apm. You bought an original one ? Is it stable ? `what are your 1st impressions ?
i bought this set: http://www.ebay.de/itm/281621471183
but when i tried to fit it i realized i needed the APM with horizontal connections: http://www.ebay.de/itm/281621481538
its from the same seller, so maybe they can replace it when you buy the set?! or buy everything seperately, doesn’t make much of a difference
in the holes you stick short pieces of 1.75mm ABS press both parts together and then use three cable ties to bind the two part together.
befor you tie them together check if ESC and motor is working as expected
thnx im also very happy with its performance. APM 2.6 is a very cool piece of hardware.
As for the screws i only used M3 V2A screws and nuts. The two parts of the arms are hold together by cable binders. That was avery cool idea from Daniel!
