Made the static feed rate modifier in the Gcode widget dim out on play
Made the static feed rate modifier in the Gcode widget dim out on play to not confuse users anymore that this was a dynamic feed rate modifier like what is in the TinyG workspace.
Thanks - that did clear up a question I had about the difference between the two.
