Made some P clamps today with a little color.
Looks good. Why the “P” design? I’ve been scrounging small blocks to put under the dumb end. Looks like you may end up with issues where the t-nut comes out. You may want to put it on the underside. Vibrations from a router would work the t-nut loose. (If you use a router)
@Ken_Campbell there are some reasons for the P. I use it to push with pressure from the side into
Some cases.
The nut is UP for picture purpuses
I just opened the whole post on Openbuilds. I see why the “P” design now. Looks like a winner.
