Looking to use just a rectangular build plate like Walter's,
Looking to use just a rectangular build plate like Walter’s, does anything know what sizes will work without any (or minimal) modification to the design?
I saw Walter has the bed mounts but there isn’t any info on what size will fit.
I use Walters bed mounts, just measured mine. 16"x14.375. ordered from midweststeelsupply.com.
Cast Aluminum Tool & Jig Plate (ATP 5) (ALI14)
Quantity: 1
Width: 14.2500
Length: 15.7500
Price: $32.99
Item Total: $32.99
Thank you very much Sean!
@Sean_B are you using a silicone heater? What dimensions did you use? Want sure if I’d have to deviate from the one listed in the BOM
@Ryan_Fiske I believe it was from the BOM, 320x320 120V 500W Heated_Bed. Contact Sivia at 梁菌菌 s@alirubber.com.
