Looking for a way to connect/disconnect my PSU from the tube.
Looking for a way to connect/disconnect my PSU from the tube. Is the following item what I’m looking for? Does the quality makes a difference? I don’t want a $5 item to kill me http://www.ebay.com/itm/322204363935
I used one in my Redsail LE400 refit. They work pretty good.
Yep, you’re just trying to keep the pixies in… That coupler works pretty well with that… I don’t think they have thumbs.
I was an electronics tech with the Australian Air Force for 10 years so i know a few connectors -it looks like bannana plugs as used in multi meters ,so is a good conector and will handle being pulled apart quit a few times.insulation looks good as well
This is a great find thanks, I was struggling with finding connectors that wouldn’t arc and were insulated enough.
