Living on the surface of the sun, Phoenix, AZ that is. I can’t make enough ice to keep my K40 cool so I bit the bullet and ordered a water chiller.
This will only bring the water temp down to the ambient room temp, it is not a real cooler. The CW5000 is the one you should be getting.
I read the info on it and it is deceiving…I would also be concerned about it. You might want to have Amazon cancel the order.
This is the lease expensive one I’ve run across that is a true freon R134A chiller.
I would agree with Anthony, I have this LightObject chiller
and it’s a true refrigeration unit, the item you are looking at is not.
I use it with 100W Reci tube and a K40 unit.
