Linux does not connect to CNC
Hi, having a problem connecting to a brand new machine, never before connected/run.
LAPTOP: Dell Latitude 5550, i5-5200U CPU @ 2.20GHz x 2
OPERATING SYSTEM: Linux Mint 21, Cinnamon 5.4.12, Kernel: 5.15.0-164-generic
APPLICATION: Universal G-Code Sender, Ver. 20251130
Firmware: GRBL (1.1h), Port: ttyUSB0, Baud: 115200/9600
MACHINE: Sainsmart Genmitsu PROVer XL 4030 v2
Computer setup & operated as Single User with full system Permissions and Dialout group membership, ‘Brltty’ file deleted.
PROBLEM: Attempting to connect to machine -
***Connecting to jserialcomm://ttyUSB0: 9600
***Fetching device status
***Fetching device status (2 of 10)…
***Fetching device status (10 of 10)…
***Connection closed
A baud of 9600 or 11500 produces denticle results. Google AI suggested adjusting the ‘connection timeout’, but I cant find the appropriate settings.
Thanks
Initial safety check; I assume you tried 115200 baud (not 11500 as you wrote)?
What happens if you try to connect with a normal serial terminal program?
tio is a good one to use if liunux based:
eg: `$ tio /dev/ttyUSB0 115200
There is also pyserial-miniterm
Try other baud rates too; 57600 is a commonly used speed on some controllers.
Google AI says you should be using 115200 for the baud rate, not 9600 or 11500
Hi, Owen,
thanks for your time. typo assumption correct, 115200 not 11500. As to ‘tio’, it’s not installed (at this time), however, /webserial.io/ returns “connected - ch340 serial converter 1086-7523”.
I’ve tryed baud rates of 9600, 57600 & 115200 with identicle results. I’m thinking it sees the control box but can’t talk to it.
The folks over @ V1 engineering had me run the command “sudo cat /var/log/syslog | grep -1 usb”, which returned (excerpt):
Jan 26 08:47:51 user-Latitude-E5550 systemd[1069]: Started VTE child process 1788 launched by gnome-terminal-server process 1763.
Jan 26 08:50:41 user-Latitude-E5550 kernel: [ 233.835331] usb 2-1: new full-speed USB device number 3 using xhci_hcd
Jan 26 08:50:42 user-Latitude-E5550 kernel: [ 233.984795] usb 2-1: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.64
Jan 26 08:50:42 user-Latitude-E5550 kernel: [ 233.984808] usb 2-1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
Jan 26 08:50:42 user-Latitude-E5550 kernel: [ 233.984814] usb 2-1: Product: USB Serial
Jan 26 08:50:42 user-Latitude-E5550 mtp-probe: checking bus 2, device 3: “/sys/devices/pci0000:00/0000:00:14.0/usb2/2-1”
Jan 26 08:50:42 user-Latitude-E5550 mtp-probe: bus: 2, device: 3 was not an MTP device
Jan 26 08:50:42 user-Latitude-E5550 kernel: [ 234.009821] usbcore: registered new interface driver usbserial_generic
Jan 26 08:50:42 user-Latitude-E5550 kernel: [ 234.009838] usbserial: USB Serial support registered for generic
Jan 26 08:50:42 user-Latitude-E5550 kernel: [ 234.012215] usbcore: registered new interface driver ch341
Jan 26 08:50:42 user-Latitude-E5550 kernel: [ 234.012693] usbserial: USB Serial support registered for ch341-uart
Jan 26 08:50:42 user-Latitude-E5550 kernel: [ 234.012867] ch341 2-1:1.0: ch341-uart converter detected
Jan 26 08:50:42 user-Latitude-E5550 kernel: [ 234.014869] usb 2-1: ch341-uart converter now attached to ttyUSB0
As you can see it is seeing the ch340 / 341-uart on the USB0 port, but I think without the MT protocol it can’t complete the handshake?
I don’t have a GRBL machine nearby but used webserial.io to connect to a Marlin 3D printer. I saw the serial port and then I connected(hit Connect 2 times ). You can see in the window Marlin is trying to send data. GRBL should show something and if you enter “$$” into the lower command area it should dump setting information.
The baudrate of my 3d printer is 250000. I would not stop testing at 115200.
SOLVED: It turns out that communications is disconnected when the Emergency Stop is down and locked, this fact is not mentioned anywhere in readily available documentation. I had the E-stop down as a safety. Thank you for time and assistance.
Thank you for following up with the solution, so the next puzzled person has a chance to find this answer. :tada:
