Zoulou
(zou)
December 15, 2021, 11:38pm
1
Hello guys,
Looking for a way to fix (prevent movement on all directions) a linear bearing rod between 2 vertical faces.
I was thinking of using a screw to tighten it, but thinking may not be strong enough.
The surfaces is some 3D printed part.
Is there something i can put between the face and the rod to hold the all thing?
Thanks
dougl
(Doug L)
December 16, 2021, 12:03am
2
on my makerbot they are all fit into plastic parts and the plastic parts are held in place with screws. If its a large diameter rod you could drill and tap the end and bolt to the end plates.
Zoulou
(zou)
December 16, 2021, 12:11am
3
The rod will be 6mm, so just one screw on every side will be enough.
Thanks
I just saw this … Ball Screw End Supporter
But not sure it will still able to rotate itself.
